1L243
Oct 07, 2013Explorer II
Check out Work and Play I believe the 30 FBW has a garage that's big and it's a bumper pull. The problem will be little living space when the toy is inside.
They make Fifth wheels with garages that more room when hauling the toys Like the FK models. But you will need a Heavy Duty 3/4 or 1 ton to haul it.
http://www.forestriverinc.com/ToyHaulerFifthWheels/workandplay/Default.aspx?page=floorplans
Something I found out that Motorhomes unless your buying a big diesel pusher are not designed to tow alot of weight. Motorhomes have frame extentions welded on them to accommodate the body of the MH. Plus, they are close to max gross weight even without a trailer. I have a couple of friends that had to spend a few thousand to upgrade the frames on their Motor Homes so the could tow over 5000lbs...
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
