enblethen
Jan 19, 2015Nomad
You should pull a little hard to get the spring tensions mast the center point. it should come down about two inches, then squeeze the springs together to remove from the bracket. they are similar to can lights in a house.
If you can get your fingers to squeeze the wires together it will take less effort to pull down
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
