ksbowman
Apr 28, 2016Explorer II
Heat the socket (female part of hitch) and keep heat to the ball to a minimum. As it cools apply the penetrating oil liberally and as it cools it will be drawn in. If you get no results then weld a loop on the ball base and build a lever to attach to it and block one side then put a hydraulic jack on the other and jack against the bed a frame. Then jar it as you jack with a hammer.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
