meleavingsoon
Apr 30, 2016Explorer
rskeans wrote:
My understanding is that the ball is in the down position and he can't get it to the top side.
Correct...the ball is in the stowed position (the ball is upside down).
As an update I did take it to a buddy's house today and he used his torch to heat it up pretty good (not red)...then we took an air chisel and worked on it for a while but no luck getting it to move.
But I do believe the heat helped clean out the corners and now when I spray PB Blaster it actually does run thru and drip some on the garage floor. So I think it had to help if nothing else but gives the fluid a better chance to work.
I am going to mix up some of the home brews tomorrow and start using them.
Phil
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
