Preston E wrote:
Its a tight fit with only a couple inches between the ramp door and the tour pak,but theres room to get around to all the tie downs.
Do you happen to know - are the back D rings mounted on a cross member under the floor, how far the cross members are apart, and if they run across the floor (rather than front to back in that area)? After reading about your broken floor I'm going to try to keep the back tire as close to one as I can. I also plan to mount my chock to a 3' by 8' piece of 5/8' plywood, which I hope will protect the floor a bit more. Will probably piano hinge it in the middle so it's easier to handle and shove under the trailer when parked for a while.
One other thought I had was that the the ramp extension might do some swinging - so if you're that close to the door you might want to try to secure it somehow so it doesn't do any banging on the back of your tour pack.
Thanks for sharing your experience.
