Thanks for the pictures. This explains the floor loading concern. Our dealer says our 347 will be coming off the line on the 26th of May or 9 weeks since we ordered it. Looks like the floor framing is centered in the garage area and the if you center your bike in that area & centered it between the d-rings it should be just about over the support member at each end.
I will bolt my condor front wheel chock "clone"(from HF)to the center framing member and add a layer of plywood 24 x 24 maybe under the rear wheel to distribute the rear tire load for our HD Ultra which weighs about 851 lbs dry.
Good luck to all you 347 owners!
