sniperduce wrote:
Thanks for the pictures. This explains the floor loading concern. Our dealer says our 347 will be coming off the line on the 26th of May or 9 weeks since we ordered it. Looks like the floor framing is centered in the garage area and the if you center your bike in that area & centered it between the d-rings it should be just about over the support member at each end.
I will bolt my condor front wheel chock "clone"(from HF)to the center framing member and add a layer of plywood 24 x 24 maybe under the rear wheel to distribute the rear tire load for our HD Ultra which weighs about 851 lbs dry.
Good luck to all you 347 owners!
Well our 2011 Mountaineer 347 THT arrived yesterday or 9 weeks from our order date. A little later than we expected but all is well now. We get to pick it up this Saturday. We are excited.........
