oldcarfun's avatar
oldcarfun
Any Night Stands?
Just thinking ahead to when we might stop driving and park a 5th wheel in Big Bear. A king bed with 2 nights stands is a top priority. Are there any fiver models with these? We need one cpap machine and she wants a real nightstand for a clock, book, etc. Any chance? Our Winnebago class A has one small and one larger nightstand on either side of the king bed.
  • Cedar Creek 36CKTS has a king bed option. The bedroom slide out is about a foot wider than the bed. Plenty of room for a small table or bench for a Ac-pap.
    B.O.
  • Cedar Creek Silver Back , king bed, night stands both sides
  • King bed in our 2007 Alpenlite 34RLR. Night stand both sides.
  • I don't know of any manufacturer that makes a trailer that is not considered a mobile home that has a king size bed with two, or even one, nite stands next to the bed. Some have a cubby but not many.
    Edit: I found a rig that has a king bed with night stands on both sides of the bed. The only problem is that it is a travel trailer and not a 5th wheel. So far, I have found none with regular night stands - only cubbys in 5th wheels.
    Cruiser RV trailers.
    My son has a beautiful Cedar Creek "Cottage" trailer that is over 40 feet long but is still considered an RV. I towed it for him from the dealer about 150 miles to his campground in upper Michigan and believe me it is not one you would want to tow around regularly. It is very tall and heavy.
    He has found it to be a very livable trailer that he uses regularly in the summer and even occasionally in the late Fall or early Spring. It has a king bed but only cubbies next to the bed on the sides. I think most manufacturers are like his. Probably the only way you will get what you want is to find a custom builder to build it.
    Good luck. :)
    Barney
  • It’s not a mobile home park. RVs only. Thank you for the
    suggestions. I’ll look at those brands. I can’t be the only
    one who needs a nightstand!
  • If it's to be parked, and not moved, why not look at park models?
    Lyle
  • I have seen several with small night stands on each side of the bed but not many that had 120 volt power in the bedroom slides. That was a must when we bought our Montana. It has two smaller shelves on each side of the bed and a 120 volt outlet on each side.
  • Both my 5th wheel and my TT came with built in night stands. A must. Clocks, lamps, cpap machines. phone chargers.
  • Check out Lifestyle and some Carriage models. Our LS has a full night stand with drawers on one side and a cut out in the wall for small items on the other side.
