Cummins12V98
Feb 16, 2015Explorer III
carpetguy2 wrote:
Like to go to a g tire.but don't think the rims can hold that pressue.I can't find anywhere where it might say.Thats why I was asking about the f385 .14 ply g rated
Just because the tire says MAX INFLATION 110# does not mean that is what you have to run.
Use your actual weight and add 5psi using the tire load inflation guide.
You will be running about 85psi I would guess.
I went from E to GYG's on 80psi rims for several years and many thousands of miles with even tread wear doing so at 85psi.
You will hear by doing so you will rip your tires off the rims that is pure Barbra Streisand! Ask GY Tech Support.
About Fifth Wheel Group
