Old-Biscuit
Jun 08, 2017Explorer III
DRY weight 10,550# really means 5th wheel is going to be at minimum 12,500# when you put all of your stuff in it...
That means a pin weight of roughly 2400# PLUS
You don't mention which F250 (Year/Trim level)
Look on door jamb, glove box etc for a 'tire load' data ----it should list Cargo Carrying Capacity (payload) of xxxx#
That is the amount of weight you can ADD to truck....passengers, stuff, hitch and pin weight.
Bet 2400# is going to eat up majority of that 'payload'
Then you need to check amount of Max Load Rating rear tires have....will they carry that additional weight PLUS trucks base weight already being supported by tires???
Mfg. published MAX Tow ratings are 'marketing dept' magical numbers.......one only reachable with a 150# driver and 20# cargo.
You will exceed RAWR, GVWR and/or payload ratings long before reaching that MAX Tow Rating.
Course you will get "I've towed for years just fine"
It is a matter of understanding and using ratings OR justifying
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
