TxGearhead
Jun 08, 2017Explorer II
I bet that pin weight will be 3,000+. I was pulling the Montana usually 12,200 loaded with a 2014 F350 diesel SRW. I was over the payload capacity of 3200. By the time you add the hitch, fill the front closet, and some junk in the back of the truck you get heavy quick.
Exactly the same equipped Ram has 4018 payload. All the diesel Fords I looked at had the lowest payload of the 3. So I assume the gas is about the same spread.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
