winnietrey
Dec 03, 2014Explorer
goducks10 wrote:
Not sure how they can lube all four hubs and do the rest in an hour. To lube the hubs right, they need to be removed. That means jacking up the trailer and removing the tires, brake drums and hubs. Once the hub is removed then the seal is ruined. A new needs put in. Just seems to me like too much work for one hour. More power to you though if you get all you say for $100.00 a year.
I wonder if the inspection fee, is separate from the maintenance items.
Tacoma RV for example lists furnace, service alone at $199, on special, Not to mention, axles hubs and the water heater service.
The contract does not say inspection, It says, you MUST PREFORM the required yearly maintenance on those items.
If they are going to do all that maintenance for 100 bucks, Sign me up!
About Fifth Wheel Group
