Rich_Mar's avatar
Rich_Mar
anyone else had this happen to them
Out for a few days in the fiver, got all set up and hooked up, went inside and turned the water heater on gas. In just a minute or so the carbon monoxide alarm went off. Cleared the area, restarted, same results. So I just turned it to electric for the trip. I have never had this happen before, 25 years. But one thing that was going on was there was a strong wind hitting the water heater side of the fiver where it vents. You think the wind could have driven just enough fumes back inside to set off the alarm?? By the way, started the w.h. at home with no problems. I've just never heard of or had this happen before.
  • laknox wrote:
    A few years ago, we were boondocking in the old Komfort, and my batteries were getting discharged so I borrowed a b-i-l's generator, hooked it up and drug it to the end of my 25' cord. The FW was wide open to the breeze (what little of it there was) at 7k' altitude. Fired the genny up and within 30 seconds, the d@mn alarm was going off. Shut the genny down, grabbed the 25' extension, hooked that in and had the genny 50' away. Fired it up again, and damme if the alarm didn't go off again. Ended up having to button the FW up almost completely (left the top vents open) to keep the alarm from triggering. Even moved the genny around a bit, but the alarm kept going off. Very annoying...
    Lyle
    Similar issue for me. I was boondocking at Talladega a couple of years ago and forgot to take my GenTuri for my generator exhaust. The wind was obviously coming from the exact wrong direction because no matter how I configured my windows, vents, door, etc. the CO alarm would go off. All open, all closed, various combinations it didn't matter. I actually have a second portable alarm that has a digital CO readout and when I put it by the built in one it would go off also, but showing a concentration number vs just making noise so I knew the built in one wasn't giving a false reading. I could run my Onan just long enough to make a pot of coffee and then the alarm would go off. I haven't forgotten the GenTuri since.
    Lyle
  • Quick question: Was it a carbon monoxide detector or the propane gas detector?
    Either way a problem, maybe the wind was blowing the flame out allowing gas to flow.
    Did you have a window open.close by water heater?
    Did you have a roof vent open?
    IS your CO Detector a stand alone or a combo LP & CO Detector?
    Water heater combustion chamber is inclosed inside the water heater tank
    Exhaust fumes can not come back inside RV unless via an open window etc.
    ****Unless seal around exhuast tube is damaged.
    CO is a product of incomplete combustion.
    Water Heater flame should be Strong BLUE Hot flame....if yellow it needs more air
  • Haven't had this problem, but agree with bpounds. Only lighting problem we had was due to spider webs, a lot of them, in the flue outside.
  • I haven't had the problem to that extent, but I have had water heater issues at high altitude if the wind is blowing at certain angles. I've had the flame huff and puff, and repeatedly re-ignite. In every instance so far, opening the outside hatch over the water heater has solved the issue. Which tells me it was a lack of oxygen due to altitude, and I think the wind would pull a bit of a vacuum somehow.
    For the OP's problem I would look at cleaning the orifice and adjusting the flame. Spider webs, wasp nest, etc. And most importantly, check the flue for obstruction.
  • No. But then we have a hybrid. Find the source. This is important
