- hondaproExplorerCollinite marine fleetwax
- cpaulsenExplorer IIMaguaris Hybrid Ceramic coating
- TerryallanExplorer III use MeQuires cleaner wax. takes off oxidation, slight scratches, and leaves a super slick shine.
- rexlionExplorerZep works well on gel coat, and will last for several years.
- dapperdanExplorerI use NuFinish, have for years. I don't seem to get the blotchy effect some are stating here. :h I only wax our fifth wheel once year, I do however wax the front cap at least two or three times a year to make removing bug splatters easier.
Lots of good suggestions here, pick one and go with it! :B
Dan - YC_1NomadDriven to perfection
Not cheap at $20 a bottle. Takes two bottles to do our 40 ft DP. After 11 years it glows. Goes on very easy and come off even easier.
If your unit is in need of it use the diluted stuff and some clay to get all the dirt and crud off. Then put on a coat that will last for a year. Use the touch up stuff to wipe it down when needed. You can do a large area before wiping it off. - ivbinconnedExplorer IIhttp://rejex.com/rejex-high-gloss-finish-that-protects/
I use this on the fifth, the boat, the truck etc.
The bugs just slide off when I wash. A great and easy product to use.
But any oxidation should be polished off first. - AnonymousI have tried many waxes over the years on fiberglass trailers, including Nu Finish, which left a blotchy finish. Now I stay with Meguiars Flagship Marine Wax. It leaves a high gloss, mirror like finish on my 2004 5th wheel. I use a 10" buffer but it still is a lot of work but worth the effort, IMO.
- Dick_BExplorerI recently used a paste wax which, if applied properly, would do the best job but it ended up with streaks even tho I used an electric buffer. Do the next time I will use a liquid was with the buffer; not sure which one.
- LwiddisExplorer IIMother’s California Gold® Brazilian Carnauba Cleaner Wax
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 03, 2021
