bigdon68's avatar
bigdon68
Anyone have an 25K Air Safe Hitch with a new Superduty
I have a 2017 F450 with a Hensley T3 hitch. I have a Retrax roll top cover and so far have wiped out 2 rails on the retrax cover because I cannot seem to get the hitch high enough.
The back of the pin box hits the retrax rail when I make a sharp turn backing up. Just ordered a 4" spacer for the T3 and really hope that does the trick.
I had a 25K Air Safe Hitch with my old F350 and I think I should have stayed with Air Safe. The nice thing about Air Safe -- even though the head may sit up high while towing it comes off very easily after you unhook to us your roll top cover.
Any help or advice would be appreciated.
bigdon68
    bigdon68
    I also have a 2017 F450 and own an Air Safe 25k hitch. I recently switched to a BW Companion because the Air Safe hitch (on lowest setting) and its Reese adapter were too high to fit under my roll bed cover without removing the head. The setup was also too high for my trailer whereas the BW hitch is just right. I also lowered my rear bed height by 1.25" which made a world of difference. If you need more bed rail clearance, going back to an Air Safe hitch and adapter would certainly help. It will make for a very high connection point too so hopefully your trailer can handle it.
    Steve
  • bigdon68 wrote:
    steadfastrock wrote:
    As long as your coach gross is less than 21K, you can lower the pin. This will require going to 5 bolts on each side.
    We had to do this with our Mobile Suites towed by our Chevy. Look for a sticker on the side of the hitch to allow the procedure.
    Good luck.
    Can not do. Over 21K
    bigdon68
    So you are over gross on the coach then? The pin can be lowered a reduced amount while maintaining the six bolts still.
    Good luck.
    bigdon68
  • As long as your coach gross is less than 21K, you can lower the pin. This will require going to 5 bolts on each side.
    Good luck.
  • Looking at your pics, doesn't look like you could gain much by trimming below the actual pin box at the point of impact to the rails. Your rig pic looks like you may be able to raise the hitch more though, without causing too much a nose-high issue.
    Jerry
  • MFL wrote:
    Posting a picture of the problem would help with responses. I have heard of similar issues, where the pin box mount needed to be trim in an upward slope to allow clearance to bed rails. You don't want to raise the hitch too high, and be towing way nose-high. If I understand the issue, I think trimming would be the answer.
    Jerry
    Check out MY PICTURES
    bigdon68
  • Posting a picture of the problem would help with responses. I have heard of similar issues, where the pin box mount needed to be trim in an upward slope to allow clearance to bed rails. You don't want to raise the hitch too high, and be towing way nose-high. If I understand the issue, I think trimming would be the answer.
    Jerry
