jmtandem
Feb 15, 2016Explorer II
I'm wondering what kind of hitch set up I'll need to safely and smoothly pull it.
Toyhaulers are built with axle placement that allows for the weight in the toy section to not make the tongue too light. However, when the toyhauler is empty the tongue weight typically would be greater than a comparable travel trailer. You might need to upgrade to an aftermarket reciever for the truck that can handle 1500 or more pounds. I would look into a Hensley or ProPride hitch or at a minimum the AirSafe system plus a weight distribution hitch.
About Fifth Wheel Group
