allcool
Feb 16, 2016Explorer
polishdon wrote:
After all my research and looking at toy haulers, I'm leaning towards a Cherokee Wolk Pack 2512. It's a 37 foot long "bumper pull". I'm wondering what kind of hitch set up I'll need to safely and smoothly pull it.
And looking for opinions from other folks pulling a trailer this long and whether I'm asking for trouble or not. lol My tow vehicle is a 2500HD Duramax, so I know I've got the truck to pull it, I'm more worried about sway and being able to fit this thing into typical camping sites.
My FSW3200+, triple axle, is almost 40' long from end to end. Its TW can approach 1 ton easy. Its gvw is rated at 13,000, but that is probably low when fully loaded up for a camping trip.
My FSW3200 tows great.
No sway and tracks straight.
Michelin Ribs XPS probably help.
As for getting into camping spots, I've never had a problem. But don't try and put a huge TH in a too small a spot. I've seen some guys with smaller rigs try to tow thru a fast food drive thru, unsuccessfully. So its all common sense and knowing your limitations. Yes, a big TH needs a big camping spot.
Now I don't know the actual weights your TH is sporting, so act accordingly...
I have towed with new 3/4 ton diesel trucks, and they can tow it, but are over their capacity for sure. The lights do point up with the WD hitch bars at full tension.
The 1 ton trucks don't sag nearly as much and the lights stay more or less level and usable.
If yours is as heavy as mine, to tow across the street,or very short trips, driving appropriately slow and careful, a 3/4t truck should work. At night you will be challenged for enough light. To take a cross country trip, a 1 ton at the least, for my rig.
You can spend a lot of money on the real fancy complicated WD/sway control hitches. IMO, unless you have a sway/towing problem, they are not needed. Most of those fancy type hitches like the Hensley don't have big enough TW capacity for the Biggest heavy Toy Haulers. Regular WD with sway control, like Blue ox and Reese, make some heavy duty WD hitches that work fine.
My advice, make sure to get it on the scales to get an accurate real world weight.
Use the correct tow vehicle and WD hitch for the TW weight and GVW. Get LT tires, don't trust the ST china bombs it probably comes with.
You should be fine...
jmo
About Fifth Wheel Group
