MFL
Mar 04, 2021Nomad II
ACZL wrote:
IMO it's a no go. Truck should weigh in around 8600# +/-. Going by replies from others, the RV's dry weight is 14k and max of 16k. You will be at max capacity all the way around if not over on some. I had same truck, but when we upgraded RV's we were in same situation as you. Yes truck towed it fine and I loved the truck, but didn't like being right at max on everything. Dry weight of new coach was 14k and max was 16k. Fully loaded, pin was 3700, RV 16,000, total weight on truck 12,300, combo 24,600. Ended up getting a DRW 350 and night/day diff in towing. Yes the DRW sux in the snow, but for towing north of 15k max RV weight, you are in DRW territory.
Dry wt is just 12K with a large CCC, loaded GW likely 14-14.5K, kind of reason OP said the numbers fit.
Jerry
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
