JIMNLIN
Sep 18, 2017Explorer III
Anyway, so far what I am seeing here is that as long as I am at or under 22,000lbs GCVR with a max 3500lbs pin weight, I am within spec and technically legal. I guess a trip to the scales to tell me my "regular" truck weight is next so I can see what I have left over for the trailer out of the 22k total.
Be sure and get separate front and rear axle weights. A gross weight doesn't tell you much....if your over axle/tire load limits.
Sometime in the mid '00 GM shot themselves in the foot with the DRW truck. They actually lower RAWR down to 8200-8400 lb range by using lower rated rear spring packs for a softer ride. They admitted the mistake and upgraded the whole truck in the late '00s and went with a 9375 rawr with the same AAM 11.5" rear axle. AAM give the axle a 10xxx lb rating...one tough axle.
Upgrade the rear spring packs would fix that issue.
GM did have overheating issues with the Dmax LLY (??) engine . Check out some of the GM diesel websites for input on these trucks and what the fix was.....or any issue you might think of.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
