bpounds
Sep 04, 2013Nomad
retired-tech wrote:
per ford use as much cetane boost as you like but not anything with anti gel. the anti gel works weird with the wax in the fuel. the higher the cetane the better the burn.
I don't recall ever seeing anything like that from Ford. Anti-gel additives are okay, and maybe even necessary. However, Ford says to not use any additive with alcohol. Since alcohol disperses into water and fuel, it will cause water in the fuel to pass through the filters and will damage the injectors. Some old style anti-gel additives were mostly alcohol, but I'm not aware that any of those even exist these days. All the manufacturers are pretty clear about no water and no alcohol allowed. No dispersants allowed. The goal is to separate water out, not disperse it into the fuel.
About Fifth Wheel Group
