Wild_Card
Jan 07, 2017Explorer
SkiSmuggs wrote:
I have the rail mount Andersen on the Reese puck adapter in my short (6'9") bed F350. I install it with the ball to the rear and the adapter has the hole behind the pin as I have an extended pin box. I have carefully done 90 degrees while turning around in a parking lot. Prior to that, I had a Reese 16K hitch and could only get about 75 degrees before either hitting the bed sides or cab.
BTW, the puck adapter is heavier than the Andersen. :)
That's how they set mine up even though I have a long bed. Wander if it being behind the axel a little if it unloads the steering axel? Might have to do some testing.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
