cummins2014
Aug 05, 2020Explorer
Njmurvin wrote:
I checked with Andersen about the bed support requirements for GM trucks. They told me specifically that the 2020 models were redesigned and did not require any reinforcement. I used a thin rubber mat under the AUH and when I removed the hitch and mat after my first trip. There is not a trace of evidence that the hitch has ever been in the truck bed. Doesn't the truck's gooseneck ball provide the bulk of the support?
I am sure the ball has some of the support, its designed the same way the B&W is ,and had to be shimmed . The B&W has done the same as the Andersen in some cases ,dented up the bed. Easy solution if it does add the shims same as B&W had to do.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 14, 2026
