Mike_E_
Jan 17, 2017Explorer II
Searching_Ut wrote:
I have a backflip on my shortbed Ram, and so far haven't had any issues. I use it in the 3/4 folded position though not all the way up against the window. With a shortbed you want to be able to see the 5er when backing into a spot because if you turn sharp enough it will hit the cab even with cutouts. The underside of the trailer hasn't ever contacted the cover even in a sharp turn where I'm only a couple inches from the rear window. I do watch it close if I'm on really uneven terrain. I've used it with both and Andersen ultimate hitch, and more recently with a B&W companion.
Perfect. Just the info I was hoping for.
I'm going to be using a rail mount Andersen.
Thanks everybody. Gonna' make the call....
Mike
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 09, 2026
