Devocamper
Oct 09, 2016Explorer
rhagfo wrote:
Interesting several versions, one has a wireless monitor panel, there is also a smart phone app.
Not cheap, but looks to use a technology that will provide accurate readings.
Kit
Sensor only
don't bother with the inside monitor it is not very accurate but does change but the phone app works much better , I have had to replace one battery this season out of the two sensors . I installed the sensors in the spring, one note of caution don't over tighten your tanks hold downs if you do you end up flatting out the rubber spacer and crush the sensor , there was a screw under mine and the sensor got damaged but still works , I am thinking of making some sort of solid spacer for next year the product seems to work well with the phone app .
About Fifth Wheel Group
