Devocamper
Oct 09, 2016Explorer
JMelton wrote:
Dumb question here...with liquid propane being -44°, could you not use a IR Thermometer gun to determine levels? Since I haven't yet purchased my FW, I'm inexperienced in this particular topic.
This is by no means a must have item it is more of a gadget for most unless the access to your tanks is difficult . With this you can check your propane level from anywhere within the blue tooth range of your phone or tablet. we are thinking of moving from a fifth wheel to a truck camper and the tanks are behind each other on a truck camper so this would be good for that application , but not a must have device at all in fact if you have the switch over regulator you just need to take a peek at the window on the regulator once in a while to see if the tanks switched over ,.
Mike
About Fifth Wheel Group
