Johndanielscpa
Feb 17, 2016Explorer
Although the basement is well insulated, it is heated when you run your furnace as air will circulate through the basement when the furnace is running. If you don't run the furnace, no heat. The tank pads assist in that case. You should have two switches - one will run them on 12 volts and the other on 110 volts.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
