BB_TX
Oct 02, 2014Nomad
Look carefully at the truck specs. Depending on configuration, Ford F150s may have a payload rating of around 1000 lbs at the low end to over 3,000 lbs at the high end. GM and Ram probably have a similar spread.
And there are many 5th wheels with dry pin weights of 1000 to 1,200 lbs. So the right 1/2 ton truck and the right 5th wheel and you would be fine.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
