RKW's avatar
RKW
Are your slides independently actuated?
I was talking to a salesman about an Open Range "The Light" and he mentioned that the two opposing slides were independently actuated. He insinuated that other brands had slides that operated only simultaneously. He also mentioned that the slides on that particular RV could be opened out to any degree you wanted, that is to say a little or all the way or anywhere in between. That statement made me wonder if that feature was unique to most brands or common in most brands. Thoughts on this?
    Open Range are separate slide motors. They have the BAL cable system which lightens the unit 3-500# per slide. All slide motors can be gotten to from inside the rig and worked with a drill with the flexible shaft supplied. Have not had a bit of trouble with the motors or the cable.
  • My Winni Raven operates individually activated slides. and no problems
  • The three slides on our Cougar are operated independently with their own switches. However, I do not have two slides that are directly opposite each other, but I'm not sure why them being opposite each other should matter.
  • On my Cardnial, the front two 10ft slides are cable operated and have separate switches. The cable system for these two slides allows for a full size basement storage as there are no hydraulic rams to move the slides. The other three slides (two bedroom and large kitchen slide) are all hydraulic operated from one switch or remote and can be indivually selected if you do not want them all to open.
  • Can't speak for other brands - or newer models.
    2006 Jayco.
    Slides operate independently.
    Only reason I can think of to *partially* open slide/s, is for access to something the slide/s block when it (or they) are "in".
    BTW - handy *if* the slide blocks something when it's in.
  • We have a '08 KZ Durango with 3 slides, operate electrically and have 3 independent switches that can be operated in any sequence. With all 3 slides closed (in)we can use every aspect of the RV.....a nice feature when on the road.
