time2roll
Oct 02, 2014Nomad
Is it set to Flooded Battery? This program holds 14.6 volts two hours then drops to 13.8 float. OK for in use but seems high for storage.
Change to GEL setting for a lower 14.2 boost voltage. Still going to run two hours and this is normal while in use.
http://www.system-pv.com/files/2215.pdf last page for charging specs.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
