jetboater454 wrote:
A lot are installed with lag bolts due to no access under the floor.Use 1 1/2 to 2" lags,predrill the hole,fill it with epoxy,install the bolt.Go about every 6" staggering the bolts on each side.That's what I did in the show car hauler.
This is what I did but I only rely on the e-track to hold my 650 dirt bike and the 4 wheeler. When I haul the V-Max I also use a titan chock as well as the factory tie down locations. I've hauled this way for 10 - 15k miles. My only variation was to use every other hole or so...
