5th_wheelers's avatar
5th_wheelers
Atwood hot water heater
We have a 22 ft 5th wheel with an Atwood MPD-91043 water heater. I have the temp control all the way up and the water will still not get hoy enough. If I run a bit of water then wait 10 min the water is hot enough. It seem like the tank will not cycle enough. Any ideas from anybody? Thanks
  • Typical causes of water temp problems on pilot water heaters
    INSUFFICIENT WATER TEMPERATURE
    Temperature selector out of place--------------Re-set to desired position
    Valves improperly positioned---------Check that bypass valve is closed
    Improper air adjustment------------------------Adjust main burner air shutter approximately 1/4 way open
    Partial main burner blockage------------------Remove blockage (run bottle brush thru tube...clean ofifice with alcohol)
    Improper main burner adjustment------------Re-align main burner and main burner orifice holder (should be 'straight' shot thru tube)
    Flame spreader mis-aligned--------------------Re-align or replace main burner (should be parallel to end of tube)
    Blocked “U” tube--------------------------------Remove blockage (run bottle brush thru combustion/exhaust chamber)
    Also check any hand held shower wands.......turned off at hot/cold knobs and not just on handle.
  • Bypass valves in the correct position after dewinterizing?
