Old-Biscuit
Mar 30, 2018Explorer III
ScottG wrote:
OB, anything like that for Suburbans?
Suburban uses a 130*F normal......optional 140*F
Both preset.non-adjustable
High is same on both.
Normal/High come as a SET wired together on a backing plate
120V AC Set for electric and 12V DC Set for the propane
Propane only uses same draw pan with cut out for electric and propane t-stats but only propane set used
DIYs have used that empty space when electric set is missing to install a residential t-stat that is adjustable and wired into the propane set.
BUT that is IF WH is Propane only
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
