JRMunn
Mar 31, 2018Explorer
cmarq - Saw your post after mine was submitted. Where did you get the adjustable thermostat? This sounds like a good solution. I have also had leaks (drips) at the outlet and inlet of this HWH. Turned out that the plastic nipples used at the factory (? - I'm not the first owner) transitioned from round ends to square in the middle and could not be tightened enough. Of course, they were 1 3/4" long and the only new ones I found locally were all round and either 1 1/2" or 2" long. The 2" seem to work okay, but changing nipples requires taking off the tubing connectors, which then needed new gaskets to stop new leaks.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
