- Old-BiscuitExplorer IIIThe Atwood in your 2009 HH II uses one set of T-stats for temp control...be it electric and/or propane
T-stat (normal control) Opens at 140*F to stop any heating and Closes at 110*F to start heating cycle
ECO (Energy Cut Off---Hi temp) Opens at 180*F to shut down ALL heating, will trigger the RED Fault Light and 'Locks Out' any reheating cycles until system reset.
ECO self resets when temp drops below 150*F.
Fault Light/Lock Out is reset by turn On/Off Switch OFF, wait 30 seconds and then back ON (whichever heat source was being used)
Typically if ECO trips....the T-stat has failed to control temps
T&P Relief Valve is final backup. OPENS/SPEWS if temp reaches 210*F or 150PSI
T-stat AND ECO have FAILED
Atwood does have an adjustable T-stat (110*F to 150*F)
Replaces the T-stat
ECO remains the same
Atwood Adjustable T-stat Part No. 93105
Course the lower the temp will result in HOT Water running out quicker.
You can heat with electric, with propane OR with BOTH
Temp control remains the SAME....just different recovery times
Electric slowest, propane much quicker and BOTH is fastest. - ScottGNomadOne source of heat doesn't get appreciable hotter than the other and it wont matter how long you run either unless you try to shut it down before it reaches temp.
Unfortunately there is no temp adjustment on newer water heaters. - JimExplorerWith that new of a WH, it's possible you have both gas and electric. Is it possible you're running the gas all the time?
If so, I'd recommend shutting the flame off and only use electric (assuming you have that heating element). While you research how to turn the temp down.
(I mention this because I've known several RV'ers who had no idea they had a dual function water heater as the electric element switch wasn't obvious).
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
