Old-Biscuit
May 25, 2015Explorer III
You stated ....."have replaced gas valve and the thermostats with no difference"
Then you did not get t-stats tight against water heater tank wall.
I do not like Atwoods method of holding t-stats. Plastic washer pressing against a spring that has to be held compressed by three small tabs.
If tank wall is dirty where t-stats touch......t-stats won't sense temp (actually temp will go higher before t-stat opens
If t-stats are not tight.... same ----high temp before opening
If t-stats terminals/connectors not clean & tight....t-stats can open erratic
Turn water heater ON
When propane shuts off OR T&P Weeping hot water (it steams when it is released into atmosphere----doubt it is 210*F-----hot but not that high)
Collect a cup of full hot from faucet with thermometer in cup.......note highest temp reaches.
With that info...........easier to pin point issue
Post here or PM me with temps.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
