Piddlers
Feb 20, 2019Explorer
Auto Leveling
We are making the switch from a travel trailer to a fifth wheel trailer. With our travel trailer we have Andersen levelers, plastic (Lego) levelers, etc. In the event of a sloping site do you ev...
laknox wrote:GHop wrote:laknox wrote:Thank you for the information, but the blocks did not work. Okay, happy travels.GHop wrote:
I have been good at reading and following the instructions but our leveling system has only worked correctly one time. Most of the time it has an error "Out of Strock". I would love to use it but no joy. I'm happy your is working correctly
Geez, if it's out of stroke, then put some blocks under the jacks that are limiting out! If you're already doing this, then put more blocks. If it's still showing an error when you're close to level, then you've got a system problem and need to address it. A trip to the dealer for a refresher lesson might not hurt, either, just to be sure.
Lyle
Sorry for coming across a bit chippy. Fighting a cold... :-( I'd say that the system needs a re-zero. Once that's done, give it a try and if you're still getting errors, then a trip to the dealer would be in order.
Lyle
