Bird Freak wrote:
BeerCan wrote:
Bird Freak wrote:
I don't see the big deal with the Pullrite. Mine weighs less than 200# and I can remove 1 set screw and anyone can pull my 5er. I also use a engine hoist to remove hitch. Too dang old to lift heavy stuff now.
Really? According to the manufacturer it weighs 345 lbs plus 50 to 80 lbs for the rails. Did you modify yours?
Pullright Manual
I think the op is looking for lighter weight options. I use the Demco Hijacker and like the Pullright it weighs over 300lbs. I like the way it works but I had to get an engine lift to put it in the truck. Look for used engine lifts for cheap on craigslist.
.Yes Really!! before you correct me you should look at the correct hitch, Pullrite model 2700. I know what I have. Do you?
Alright Skippy calm down. Did you see the question marks? That is why I asked if it was modified. No one knew which one you had but you, perhaps if you were more clear on what model you were using there would not have been an issue.
