racer4
Jan 18, 2016Explorer
What Pipeman said x 2.
The transfer Flow 50 gal should fit under a roll up cover or a flip/fold cover. Check the dimensions on the link that Pipeman gave. The 50 gal says 14-3/4" H+ 3" for the fill neck, so 17-3/4" H.
Picture of 50 gal. tank.
If you want a retractable cover, like a Pace Edwards Jackrabbit, look at the Transfer Flow 37 gal. tank designed to fit that application.
Tank picture
Tank Dimensions Graphic
A Jackrabbit will give you better visibility out the rear window (for hitching, etc). It locks in place every 12" to allow partially closed use. Transfer Flow uses a computer controlled pump to transfer fuel (instead of gravity flow and a check ball), and accordingly cost more.
Tank picture
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
