hornet28 wrote:
mt1729 wrote:
 I added a 12 volt motorized shut off valve, which I've only needed to use when changing the spin on fuel filter I have inline.
My pickup is diesel. If it was a gasser I would put in a 12 volt transfer pump and eliminate the gravity flow. Safe travels to you.
Why didn't you just put the 12V pump in instead of the shut off?
Simple the shut off valve was just in case of emergency. It was always open. It was a gravity feed. I didn't need a pump. When my factory tank gauge came off full I knew my aux tank was empty. Fill the aux and go. No pumping no fuss no mess. Fill ignore & go.
