markc
May 27, 2021Explorer
Auxiliary fuel tank
Has anyone installed an auxiliary fuel tank in the bed of their truck? I have a 2019 F250 diesel crew cab with the short bed. Just wondering if you had problems and solutions. Thanks.
RoyF wrote:
I had a 100-gallon Transfer-Flow tank in a long-bed 2008 Ford F350 diesel. One small problem (if you even call it that) was that the amount of fuel on the display was always less than what was in the tank -- I would have about 20 gallons left when it displayed 0 gallons.
Another slight problem was that leaves and debris that collected in the one-inch space behind the tank were difficult to remove.
I recently traded for a 2021 long-bed diesel, and want to get another Transfer-Flow when one becomes available for the 2021 Fords. I do it for peace-of-mind; so that I can tow for three for four days without constantly having to worry about fuel; so that I can reach Yellowstone (for example) at the end of a driving day and still enjoy driving around for the next couple of days without having to think about visiting a station. To me, that's worth 50 cents a day spread out over ten years.
You do NOT get a transfer tank to for the purpose of finding cheaper fuel (you never save enough to get your money back), but a side benefit is that you have the option of topping-up whenever you happen to see a good price, or you can keep on trucking though a state where fuel is more expensive. But, as I said, that is secondary to peace-of-mind.
Metal transfer tanks will have a good deal of water condensation. I put a water-separation filter in the line coming out of the transfer tank. That helped to keep water of out the main tank and not overtax the truck's own water-separation filter.
