Has anyone installed an auxiliary fuel tank in the bed of their truck? I have a 2019 F250 diesel crew cab with the short bed. Just wondering if you had problems and solutions. Thanks.
Word of caution for newer GM owners and gravity feed system. You will need something to clear codes, because the newer GMs will set a pending code and your fuel guage will drop to empty if you travel approx 100 miles and the computer does detect any drop in fuel level. If the pending code is not cleared by the end of the next 100 miles it will set a Check Engine code.
