Good morning! The other day we were getting ready to head back home, when my electric awning would not work. But in my Jayco 5thwheel there is a remote control that controls the awning and slides. T...
If the remote control worked your fuse is probably good. My guess would be the manual switch you were trying to use before you tried the remote. If possible pull the panel out and check to make sure the wires are attached to the back of the switch. If the wires are tight on the switch then you will need to test the switch to see if it works.
