routemaster wrote:
This is how I made mine hope it helps.
routemaster,
thanks for the drawings. Makes good sense now. I can tell by your design and workmanship you obviously know what you are doing and have the talent and equipment to build it.
With the the Correct Track install do you feel the square tubing from one hanger to the other is absolutely necessary?
I know it would be beneficial, and as I have mentioned, I have it on my current trailer (no correct track hangers). It's going to be really costly to have someone fabricate it like you did.
One big downside I see with the Correct Track is that it doesn't look like you can use wet bolts with them.
