sandblast's avatar
sandblast
Axle capacities
A friend is looking at a 2008 Keystone Raptor 3814SS.
After searching the Keystone archived spec`s still can not find individual axle capacity for 3814SS. Looking at gross weight divided by three axles is still a guess at best. TIA.
  • Despite what some have said, toyhauler axles DO fail. My first hauler Victory Lane 35SRV came from the factory with 6000lb axles. They bent flat. Factory replaced everything between the frame and the ground under warranty including 7000lb axles and upgraded springs, wheels and tires.
    Did they increase your certified GVWR while they were at it?
  • 4x4ord's avatar
    4x4ord
    Explorer III
    My Citation 5th wheel has two 8000 lb Dexter axles. Citation rates the axles at 7000 lbs each. I don't know why that is ... could be the suspension is limiting? Could be they want extra capacity to provide for loading one side of the trailer more than the other? So the GVWR of my trailer is 15500 lbs with a total axle capacity of 14000 lbs and it has 2 x 8000 lb axles.
