Reelay
Jul 25, 2013Explorer
Axle capacity
Is there a stamp or ID tag located on the axles anywhere to ID them as to what weight capacity they can carry? {Haven't really looked yet} My trailer has drum brakes with leaf springs and shocks, six...
My trailer has drum brakes with leaf springs and shocks, six stud holes, electric brakes.
Trailer tag inside says the trailer weight is 12,078# empty. Just curious as to what is assembly was used.
You sure 12078 is not the GVWR? If it is dry weight you would have 6k axles, however most are 8 lug. If that is GVWR then axles are most likely 5200. BTW the brakes on ALKO axles are the same 2x12 5200-7000 and Dexter may be the same.
What does the placard list for GAWR?
Correct reading {may fault} 12,078# GVWR, tag on axle reads 5200..Thanks..
Chris
