aruba5er
Jan 31, 2017Explorer
Axle spacing
After going to an RV show this past weekend, I noticed the spacing between axles is 2 feet or more. Can someone enlighten me as to why? Better turning, less wear ???
cbshoestring wrote:Diesel Pushers with tag axles must also lift the tag in sharp turns.RoyF wrote:
Wider spacing means more twisting (there's some word for it) on tires. What was the make?
In the trucking world, we called it "scrubbing". They actually advertise "scrub-resistant" tires for spread axels.
You can twist the tires on a tandem as well, when "jacking" the trailer. It is just much easier (because of the forward location) to twist the tires on a tandem. Even normal turning "scrubs" the tires on the forward axel. Which is why many heavy trailers can LIFT that axel when not in use....saves on tire wear.
