OK now I am really confused. The pin fits through the spindle just fine but not when nut is installed. The left front was exactly the same as the left rear? Cotter pin twisted like someone tightened the bolt with pin in so as to get it to go through. The axles on this 5th wheel are Al-Ko now Dexter. Talked to Dexter, took about 5 different people before I found someone who could help. They are sending some different spindle bolts.
What confused me is that the right side is different, it has tang washers instead of cotter pins?? Different spindles with the flat spot for the tang washers. This is not the first time I have ran across something like this with this trailer. It almost like it was the end of a run and they didn't have enough parts to complete it so the just threw in what ever they could find.
Bill
