hmknightnc
Jun 29, 2013Explorer
It depends on the manufacture but determining GVWR for TT, FW, boat trailers and even equipment trailers is either done by adding up the axle capacity (the only kind I will buy) or by adding up the axle capacity plus the estimated pin wieght (leaves zero margin when fully loaded)
What you are seeing for axle ratings is completely normal. And yes you must adjust your equipment based on expected type of travel you are planning.
About Fifth Wheel Group
