Peg_Leg
Jun 29, 2013Explorer
Specs for the trailer weight was arrived at by adding the two axle capicities and the pin weight. Two 6,000 lbs axles and 1,500 lbs of pin weight would be 13,500 gross.
My friends CC has 7,000 lb axles and requires load range G tires. With load range E tires it would only be slighty over 6,000 lb capicity per axle.
About Fifth Wheel Group
