laknox
May 01, 2013Nomad
fj12ryder wrote:bogart661 wrote:Exactly so.
Make sure that the last motion with the truck is in reverse, if you have pulled forward it will put pressure on the jaws making it hard to unhitch.
Or neutral, if you're on fairly level ground. I can occasionally have some tightness when unhitching on unlevel ground. On time, when we were at our usual boondock site, I'd run over a partially-buried rock that was causing the FW to pull to one side and I had to back off it to get the jaws to unlatch easily. I probably could have forced the issue, but it was just easier to raise the legs and back up a foot.
FWIW, I use the 1/4" plate with my Companion, with few problems.
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
